materials not updating
Forums: materials not updating
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
Postby crackfox » Mon May 25, 2020 11:02 am
crackfox Mon May 25, 2020 11:02 am
hi,
i am using the node interface but it seems not to be updating on in certain moments.
also the linear material editor and the node based one are not always in sync.
example: i will remove a material on the left side editor, but it will remain connected in the nodal one.
crackfox
Re: materials not updating
Postby crackfox » Mon May 25, 2020 12:53 pm
crackfox Mon May 25, 2020 12:53 pm
hi,
it also seems that if i copy nodes they are treated as instances. there are uses for this but in node based workflow its a bit redundant.
the nodes i copy dont actually retain connections.
deleting material is not reversible aswell.
crackfox
Postby ChrisHekman » Tue May 26, 2020 12:00 pm
ChrisHekman Tue May 26, 2020 12:00 pm
The syncing is only one way. If you change something in the node system from the OctaneGUI side, you will need to close the unreal editor and reopen it.
If you got a desync while using unreal editor only, please let me know how you did this.
But yea, the unreal octane material editor needs another pass.
The folowing items are on the list:
- Added more preview refreshes
- Async preview rendering
- Retain connections when copying
- Undo/Redo
ChrisHekman
Postby crackfox » Tue May 26, 2020 3:24 pm
crackfox Tue May 26, 2020 3:24 pm
thanks chris,
i will keep this in mind.
i also noticed the bug reporting subforum.
should i post these things over there?
crackfox
Postby ChrisHekman » Tue May 26, 2020 6:28 pm
ChrisHekman Tue May 26, 2020 6:28 pm
crackfox wrote:thanks chris,
I check both so do whatever suits you. Bug forum is a bit cleaner though :)
ChrisHekman
Postby crackfox » Wed May 27, 2020 1:21 am
crackfox Wed May 27, 2020 1:21 am
got it, will try and parse things.
sorry for contributing to the mess:)
crackfox
Return to Unreal® Engine
Sun Jun 16, 2024 3:29 am [ UTC ]
cron
