Undo/Redo
Posted: Wed Oct 10, 2018 9:00 pm
by Sergey91
Hey guys!
Undo/Redo function doesn't work in Octane Plugin for Unity. This complicates work a lot. Could you fix it please?
Re: Undo/Redo
Posted: Thu Oct 11, 2018 9:12 am
by Xhed
Hi Sergey,
is there a location where undo/redo doesn't work? We've added support for it, but it seems that we didn't do that everywhere properly.
Re: Undo/Redo
Posted: Thu Oct 11, 2018 4:44 pm
by Sergey91
There is no particular location where it doesn't work, It doesn't work in general in Octane plugin for Unity. For example if I accidentally delete any node, I can't undo this action.
It is not even active (see attachments)
I'd appreciate if you could double-check things here.
Re: Undo/Redo
Posted: Fri Oct 12, 2018 1:46 pm
by Xhed
Your attachment isn't showing for me, it redirects me to Imgur's 404 page.
Where are you deleting a node? Are you referring to the Octane interface?
Re: Undo/Redo
Posted: Fri Oct 12, 2018 3:51 pm
by Sergey91
Yes, exactly. As we're talking about Octane, I meant any action in Octane UI - delete node, make any adjustments to the materials inside Octane plugin, literally anything that is done through Octane's UI. Does it make more sense now?
Here's the missed image
https://imgur.com/S2zaZ3Y
Re: Undo/Redo
Posted: Fri Mar 19, 2021 11:01 am
by manusd
I`ve got the same problem. Any solution to this?
