Maximum limit of 1 GPUs has been reached?
Forums: Maximum limit of 1 GPUs has been reached?
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Postby nights » Tue Oct 24, 2017 3:00 am
nights Tue Oct 24, 2017 3:00 am
I have two GPUs in my computer, (needed for dual 4k @ 60hz), and when i try to render by Octane in Unity I get this error:
Can't activate device 0, because the maximum limit of 1 GPUs has been reached.
CUDA error 999 on device 0: unknown error
-> failed to bind device to current thread
device 0: failed to initialize resources
I'm fine with only using one GPU for rendering, but idont want to remove the other GPU cus then i cant use my computer.
I can see that under Devices in PBR Settings there are two cards but only one (960 gtx) is selected as "active" and the other isnt.
Shouldnt this be enough?
Please let me know how to proceed!
Thank you!
nights
Re: Maximum limit of 1 GPUs has been reached?
Postby Xhed » Tue Oct 24, 2017 8:21 am
Xhed Tue Oct 24, 2017 8:21 am
Can you check if your drivers are up to date? And what happens when you disable your current active GPU, and enable the other one?
- Rick
Xhed
Postby nights » Tue Oct 24, 2017 12:16 pm
nights Tue Oct 24, 2017 12:16 pm
Xhed wrote:Can you check if your drivers are up to date? And what happens when you disable your current active GPU, and enable the other one?
They are updated only a few days ago. What do you mean by disable though, the active flag in PBR Render settings tab or through device manager?
I'm guessing it will work if i do the latter but obviously i dont want to disable my GPU everytime i'm using Unity.
nights
Postby Xhed » Tue Oct 24, 2017 1:59 pm
Xhed Tue Oct 24, 2017 1:59 pm
By toggling the flag in the Device section of the settings window. First disable your active GPU, and then enable the other one.
- Rick
Xhed
Postby mojave » Tue Oct 24, 2017 7:50 pm
mojave Tue Oct 24, 2017 7:50 pm
What you see is an undefined error that is generated from the Nvidia driver, this may happen for a number of reasons, usually during initialization, and may be happening due to some faulty HW component among other reasons.
What's the exact version of the plugin are you using (version number and tier (T0/T1))? This is displayed in the plugin's main window.
Is this happening for all scenes every time or just with a number of them -in which case could you share one for us to test-?
Please also try switching the device using Xhed's indications and let us know how it goes.
mojave
Postby nights » Thu Oct 26, 2017 12:41 am
nights Thu Oct 26, 2017 12:41 am
Yes, so i already tried the active flag of course. After I install only one of the cards is active anyway so i think this is already handled correctly.
Whatever i do with the settings i will get that error. And afaik yes this is consistent behavior in any scene and after each installation.
Since i already have the latest drivers for both cards from nvidia i'm not sure what can be done else..
I will try to make a new scene with just a box and see what happens then.
nights
Postby Xhed » Tue Oct 31, 2017 9:18 am
Xhed Tue Oct 31, 2017 9:18 am
If you disable your working gpu in your system settings, or remove it from your system (so that only a single gpu is active in windows), does the error still occur?
- Rick
Xhed
Postby alecmaassen » Fri Dec 01, 2017 10:05 pm
alecmaassen Fri Dec 01, 2017 10:05 pm
Just to confirm, can Unity only use one GPU in octane?
We have a computer with a 1080ti and a 1080 in it, and we can only get one card to work at a time?
alecmaassen
Postby Xhed » Fri Dec 01, 2017 10:18 pm
Xhed Fri Dec 01, 2017 10:18 pm
When using Tier 1, only a single GPU can be used by Octane.
- Rick
Xhed
Postby alecmaassen » Wed Dec 06, 2017 9:58 pm
alecmaassen Wed Dec 06, 2017 9:58 pm
Okay thanks
alecmaassen
Return to Octane for Unity
Users browsing this forum: No registered users and 24 guests
Fri Apr 26, 2024 3:16 pm [ UTC ]
