Animation output issue 28.x
Forums: Animation output issue 28.x
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby J.C » Fri Mar 08, 2024 11:10 am
J.C Fri Mar 08, 2024 11:10 am
When rendering an animation and Octane Output is selected for file saving Blender output also saves images. This results in duplicate files.
Could you fix it and make sure Blender saves either using Octane Output or Blender output or both?
System – Windows 11
J.C
Re: Animation output issue 28.x
Postby linograndiotoy » Wed Mar 13, 2024 10:27 am
linograndiotoy Wed Mar 13, 2024 10:27 am
An "Exclude Beauty" option has been added for that.
linograndiotoy
Postby J.C » Fri Mar 15, 2024 9:39 am
J.C Fri Mar 15, 2024 9:39 am
You must have misunderstood me. When Octane Output is enabled Blender ALWAYS saves file using default Blender output. This happens weather Exclude Beauty in Octane output is enabled or not.
This results in extra files that were not supposed to be saved.
System – Windows 11
J.C
Postby J.C » Mon Apr 08, 2024 8:51 am
J.C Mon Apr 08, 2024 8:51 am
The bug continues in 28.13
Moreover when project path is set to "//" Octane output does not save the file.
System – Windows 11
J.C
Postby linograndiotoy » Tue Apr 09, 2024 3:23 pm
linograndiotoy Tue Apr 09, 2024 3:23 pm
There's no way to exclude Blender's output image, sadly.
I normally use it at my advantage, setting Blender's output to an animation format (mp4). That way I can get a preview of my animation once the render is finished.
About the "//" saving issue, can you please explain it better with an example?
Thanks.
linograndiotoy
Postby J.C » Wed Apr 10, 2024 2:19 pm
J.C Wed Apr 10, 2024 2:19 pm
Hi Lino, if you put double slashes "//" in output path Blender knows this is the location of a project file and will save there the rendered images. If this is used in Octane output path the file is not saved. Only Blender output is being saved.
System – Windows 11
J.C
Return to Bug Reports
Sun Apr 28, 2024 11:41 am [ UTC ]
