image refresh not working in shader editor
Forums: image refresh not working in shader editor
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby protovu » Fri May 22, 2020 1:28 am
protovu Fri May 22, 2020 1:28 am
Hello,
Currently in Blender_Octane_Edition_2020.1_21.7_stable, for Win10.
Image files are not reloading upon clicking the reload button.
Thank you
amd 3090
2 rtx 2080s
64 r
protovu
Re: image refresh not working in shader editor
Postby pegot » Fri May 22, 2020 2:58 pm
pegot Fri May 22, 2020 2:58 pm
Not sure if this is the same issue but I started having lots of crazy refresh issues with 21.7. Materials are often not updating unless I plug/unplug them or hide and then show some geometry. Materials downloaded from the Live DB seem to be the most problematic. Very difficult to work interactively. Even if I completely unplug a material from its output node, the change is not reflected in view port and still shows the rendered shader.
Win 10
3.7Ghz i9 10900k / 64GB
ASUS STRIX Z490-E
PSU: PowerSpec 850Wd
RTX 3090 Asus Tuff
Network rendering:
Win 10
4.2Ghz i7 7700k / 64GB
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 Ti EVGA Hybrid
RTX 3080 ASUS Tuff
GTX 1080ti SC Black (wc)
pegot
Postby protovu » Fri May 22, 2020 3:27 pm
protovu Fri May 22, 2020 3:27 pm
Perhaps a different issue. I only guess this because I use another Octane plugin for a different software, Carrara.
It also has this reload texture issue. In the case of Carrara, reloading the scene updates the texture, and the reload button does nothing, like now with Blender.
But that said, the Carrara plugin displays none of the issues you describe.
One annoying workaround for Blender reload: insert the wrong texture - one you don't want, and then insert the correct texture. This updates the render preview.
protovu
Postby protovu » Wed Jun 03, 2020 8:12 pm
protovu Wed Jun 03, 2020 8:12 pm
Anything happening with this?
Image refresh does not work in shader editor.
If helpful: The refresh button of the shader editor does refresh the image within the UV editor, but not within the shader editor, nor with the rendered image.
protovu
Return to Bug Reports
Fri Apr 26, 2024 12:14 pm [ UTC ]
