Vram issue again
Forums: Vram issue again
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Vram issue again
Postby dreif » Sat Oct 20, 2018 12:55 am
dreif Sat Oct 20, 2018 12:55 am
Hi. I started a new .blend file in 16.2.6 and after modeling a relatively simple mesh
I did some interactive renders and noticed what I thought looked to be high Vram
usage. I saved and opened the same .blend file into 15.3.1 stable and indeed there
was quite a difference in Vram usage, over 1000M. I previously reported having the
same issue between 15.1 and 14.0 back in April, 2018.
(Current Nvidia driver 398.82)
Win 7x64/GTX TITAN/Amd Phenom IIx4 955/16gb (The render tra la la)
dreif
Re: Vram issue again
Postby aufwind » Sat Oct 20, 2018 7:29 am
aufwind Sat Oct 20, 2018 7:29 am
if you're using the path tracing kernel, it's probably related to the Parallel samples settings,
the default used to be 8 and is now 32, which uses much more vram but is faster.
Reasonable settings to my findings are between 8-16 (if you have enough vram left).
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
aufwind
Postby dreif » Sat Oct 20, 2018 5:28 pm
dreif Sat Oct 20, 2018 5:28 pm
That seems to be the issue aufwind, thank you very much for the info! :-)
dreif
Return to Bug Reports
Users browsing this forum: No registered users and 15 guests
Fri Apr 26, 2024 5:46 am [ UTC ]
