CHANGES SINCE LAST RELEASE
- Implement an asset version updater in the Blender Asset Browser
- Support using node group for scatter surfaces
- Support preferences to decide "Copy Properties When Changing Node Type" or not(disable kernel node value copy feature by default)
- Rename the ""Hide Original Mesh" to "Hide Mesh" and move it to the top of octane mesh property panel. Now users can use it to hide mesh in all cases.
- Disable the "Realtime" option when shared surface is off, which is not available in plugins without shared surface feature
- Check whether the modifier is actually enabled when processing geo nodes case
FIXES SINCE LAST RELEASE
- Fix missing Material Output and World Output in the Shader Editor
- Fix curve edit update issue
- Fix multi-edit problem
- Fix the invisible scatter issue when entering edit mode
- Fix the render problem when involving multiple sockets with the exactly same name
- Fix issues of "Render as Octane Hair"
- Fix the missing texture problem when using Octane DB
- Use fixed offset when adding new node
- Bug fixes
HOTFIXES 29.4.1 (19/03)
- Enable Octane addon by default
- Fix the light beam problem of Analytic light
You can read about new features of OctaneRender™ 2023.1.2 here:
viewtopic.php?f=24&t=82820
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 28.12.1 (4.0)
Octane Server - Studio+ Edition - 28.12
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Studio+ Edition - 28.12.1
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
