NEW FEATURES SINCE LAST RELEASE
- Upgrade the color vertex implementation according to the changes of Blender 3.4
- Enhance the material converter feature
- Optimize the Orbx/Alembic export. Now the built-in image data will not be transferred repeatedly when exporting Orbx.
- Added "Position" sockets in the Gradient Map node
FIXES SINCE LAST RELEASE
- Keep the current position for nodes when duplicating Lights
- Fix the OCIO UI traceback
- Fix the rendering issue of the Open Subdivisions settings
- Fix the real-time update issue of the subdivision settings & sphere attributes
- Hide the unused compatibility settings in the kernel panel
- Hide the shared surface panel and fix tracebacks
You can read about new features of OctaneRender™ 2022.1 here:
viewtopic.php?f=24&t=80814
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 27.11 (3.4.1)
Octane Server - Studio+ Edition - 27.11
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
- Code: Select all
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Octane Server - Prime Edition - 27.11
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
