OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
NEW FEATURES SINCE LAST RELEASE
- Updated to Octane 2021.1.RC3
- Supported more custom AOV passes(up to 20)
- Supported more global texture passes(up to 20)
- Supported Camera Data in Render AOV node tree and Composite node tree
- Supported Object Data Node in the Octane Composite/Render AOV Node Tree
- Added the "environment depth" in the Z depth AOV node
- Added the "shading enabled" and the "highlight backfaces" in the Wireframe AOV node
- Added the "orbx" extension in the export filename if necessary
- Added "Quick-Add NodeTree" button in the node editor header for creating a default node tree automatically
- Added Baking Texture
FIXES SINCE LAST RELEASE
- Fixed the min/max issues for float inputs
- Fixed the precision issues for float inputs
- Fixed Live/Local DB material issue
- Fixed the issue that the "Quick Add NodeTree" replaces other windows' node trees
- Fixed the duplicated "Object Data nodes" in the search list
- Other bug fixes
You can read about new features of OctaneRender™ 2021.1.RC3 here:
viewtopic.php?f=33&t=78516
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 24.4 (2.93.4)
Octane Server - Enterprise Edition - 24.4
Linux
Installation:
- Just run the installer to see its command line keys.
- If you need to run OctaneServer - run it as daemon:
- Code: Select all
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 24.4 (2.93.4) Linux
Octane Server - Enterprise Edition - 24.4 Linux
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
- Your Hardware specifications (unless they are included in your signature)
- A clear description of the issue you have found
- Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
- Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
