OctaneRender™ for Blender 2023.1.2 - 28.13 [STABLE]
Forums: OctaneRender™ for Blender 2023.1.2 - 28.13 [STABLE]
Postby azen » Wed Apr 03, 2024 2:44 am
azen Wed Apr 03, 2024 2:44 am
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Support using object layer map as inputs of scatters
  • Support open subdivision for curves
FIXES SINCE LAST RELEASE
  • Fix emission texture link problem
  • Fix some update issues of the curve objects
  • Optimize resource clear process
  • Enhance material converter
  • Fix crash when using EEVEE/Cycles with Octane world output
  • Minor Bug fixes
HOTFIXES 28.13.1 (11/04)
  • Fix a particle emitter rendering issue
You can read about new features of OctaneRender™ 2023.1.2 here:
viewtopic.php?f=24&t=82820
The installation consists from two parts:
1. OctaneRender™ Server
2. Blender - OctaneRender™ edition
After the server is run - you can start rendering (or open a rendered view) from inside Blender.
Windows
Blender Octane Edition - 28.13.1 (4.0)
Octane Server - Studio+ Edition - 28.13
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Blender Octane Edition - 28.13 (4.0)
Linux
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
Please note, in regards to Bug Reporting:
- Bug Reports in this section refer to plugin-specific bugs only. Bugs originating from the Octane Standalone should be reported to the Standalone Forum section instead
- For faster troubleshooting, please provide as much information as possible. Please include:
  • Your Hardware specifications (unless they are included in your signature)
  • A clear description of the issue you have found
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots. If possible, files for testing would also be appreciated).
  • Whenever possible, please confirm that this issue is only happening in the plugin, and not also in the Standalone Edition (if the bug occurs in both, it is likely that this issue should be reported in the OctaneRender Standalone section of the Forums).
- Please bear in mind - we are primarily an English-Language Forum. Please do not take offense if we request further clarification due to language differences.
azen
Return to Releases
Thu May 23, 2024 6:25 am [ UTC ]
