OctaneRender for Maya 2020.2.3-19.13 [OBSOLETE]
Forums: OctaneRender for Maya 2020.2.3-19.13 [OBSOLETE]
Moderator: JimStar
Postby JimStar » Tue Apr 13, 2021 11:02 pm
JimStar Tue Apr 13, 2021 11:02 pm
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2020.2
Maya® Version Requirements
This release will work with Maya® Versions 2017, 2018, 2019 and 2020 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2020.2.1
Changes since version 19.11:
  • Integrated the 2020.2.3 engine.
  • Improved the Octane lights' presentation in Maya's viewport, to make them better visible from sides.
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
JimStar
Re: OctaneRender for Maya 2020.2.3-19.13 [STABLE]
Postby Vyoor » Wed Apr 14, 2021 2:24 pm
Vyoor Wed Apr 14, 2021 2:24 pm
Hi!
What's about Maya 2022 support?
Cheers!
i7, 4x GTX 780, Maya.
Vyoor
Postby BK » Thu Apr 15, 2021 4:50 am
BK Thu Apr 15, 2021 4:50 am
Vyoor wrote:Hi!
Cheers!
Hi Vyoor,
Thank you!!
Unfortunately, we are in the middle of reworking for OFM's Octane render passes which is a high priority task for us.
We are planning to add support for Maya 2020 with OctaneRender 2021 and keep the 2020.2.x branch for production.
We hope to get it done ASAP!!
cheers
Kind Regards
bk3d
BK
Postby andrey.krivulya » Thu Apr 15, 2021 7:35 am
andrey.krivulya Thu Apr 15, 2021 7:35 am
Oh, yeah =) Finally =) Thank you very much for this update!
win 10 /64x Intel Core i9-11980HK - 64Gb RAM - 3080 Laptop - 16Gb VRAM - AERO 15 OLED YD
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
andrey.krivulya
Postby g0ll4m » Fri Apr 16, 2021 7:26 pm
g0ll4m Fri Apr 16, 2021 7:26 pm
Exposure setting in octaneColorCorrectTexture should be 0 default. 1 equals a change from current value in texture color.
4 GTX 690's 4 GTX 780Tis 32 gb ram
g0ll4m
Postby itsallgoode9 » Thu Apr 22, 2021 1:12 pm
itsallgoode9 Thu Apr 22, 2021 1:12 pm
Is the universal camera vignette broken? I was randomly trying to use it last night and it didn't seem to have any affect at all
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
itsallgoode9
Postby BK » Thu Apr 22, 2021 10:50 pm
BK Thu Apr 22, 2021 10:50 pm
g0ll4m wrote:Exposure setting in octaneColorCorrectTexture should be 0 default. 1 equals a change from current value in texture color.
Hi G0114m,
Thank you for reporting this!
We have fixed it for the next release.
Cheers
Kind Regards
bk3d
BK
Postby BK » Thu Apr 22, 2021 11:21 pm
BK Thu Apr 22, 2021 11:21 pm
itsallgoode9 wrote:Is the universal camera vignette broken? I was randomly trying to use it last night and it didn't seem to have any affect at all
Hi Itsallgoode9,
Thank you!! It seems to be working on our side.
The workflow we did is to change the Octane Camera type as Universal from the dropdown.
Then increase the Opt. vignette distance value.
Ah sorry! we did find there are two Abberation rollouts. This will be fixed for the next release!!
cheers
Kind Regards
bk3d
BK
Postby Jolbertoquini » Thu Apr 29, 2021 9:08 am
Jolbertoquini Thu Apr 29, 2021 9:08 am
Thanks for the update Guys!
I was checking something about universal camera the depth field options and the split focus "diopter focal depth" should be the same unit then the "depth field" default 100 and diopter default 1.110 looks like the option is set in meters so we can't type similar number and offset if we want we have to calculate manually which is terrible specially when we use scene scale at "0.01" to have scene in CM as defaut maya units most be something weird on the code I think.
Because if my depth is set at 100 for example and I want split my focus at 150 if type 150 doesn't work I need actually type 1.50 can be really confusing to use the tool.
Cheers,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Max'd out CPU usage?
Postby pixerati2 » Fri Apr 30, 2021 4:04 am
pixerati2 Fri Apr 30, 2021 4:04 am
I've never noticed this before, probably because I've never looked...
But on my 32 core threadripper I'm getting 100% CPU usage across all cores when I enable Octane in the viewport. It actually doesn't seem to cause problems with other apps; am I to assume that the Octane plugin takes whatever it can get of spare CPU cycles or something? Or is this a bug with the current build? Maybe this is old news and I've just never paid attention. As soon as I switch back to Viewport 2.0, CPU usage returns to normal.
Not seeing this CPU usage with OctaneRender standalone.
pixerati2
Next
Return to Releases
Fri Apr 26, 2024 1:04 am [ UTC ]
