Hi, after gathering feedback from a lot of people that wanna use the plugin, we all feel that a revamp is essential to get things working to a good degree. As in comparison to RS, octane plugin is much more involved and way less functional.
- Loose the /shop /mat context render target, have everything on the /out ROP
- AOVs in RS are so simple and easy to use - stick to this UX/UI (see how easy it is to setup a puzzlematte in RS compared to Octane)
- Having to manually add attributes on a per object basis is an extra step RS doesn’t have
- The whole Vertex Attribute node in the /mat context is confusing
- Icons for /mat nodes
- The order of dual mix, blend /mat node inputs is the opposite from every other in implementation (incl RS)
- A dome light/ a sun/sky in obj and remove all those options from render target. Expose rgb color on the dome
Please, let's make the plugin equal to RS if not better.
Thank you.
