Create nodes in the correct context.
Posted: Fri Mar 16, 2018 9:55 am
by fantome
Hi guys,
This is really a tiny problem. I would love that octane create the node in the correct context.
Actually
- if you are at /obj level and want to create an octane ROP inside a custom ROP networks name foobar
- the Octane ROP node will be created in the default ROP Context, not the custom foobar network.
- so you have to go to the default ROP context CTRL+X the node , go back to foobar networks and CTRL+V the node.
It's a small things but that would be great if all octane nodes were created were you ask them to be created.
Cheers
E
Re: Create nodes in the correct context.
Posted: Sat Mar 17, 2018 12:06 pm
by juanjgon
The problem is that the tab "Render->Octane" option is using the shelf tool to create the ROP node, and this tool is a script that always adds the ROP in the /out network.
But if you the Octane ROP from the tab "Custom->Octane" option, the ROP node will be created inside your current network, as expected.
Hope this helps,
Posted: Sat Mar 17, 2018 12:55 pm
by fantome
thanks for your answer Juanjo ! looks good enough for me.
Cheers
E
