Dome light
Forums: Dome light
Sub forum for feature requests etc
Dome light
Postby thanulee » Sat Apr 16, 2022 8:57 pm
thanulee Sat Apr 16, 2022 8:57 pm
Hi, is that possible? The way we setup those things now is non intuitive.
thanulee
Re: Dome light
Postby juanjgon » Mon Apr 18, 2022 8:46 am
juanjgon Mon Apr 18, 2022 8:46 am
The dome light is an environment texture, as you can configure in the render target node, isn't it? Octane doesn't have native dome lights itself.
juanjgon
Re: Dome light
Postby thanulee » Mon Apr 18, 2022 8:34 pm
thanulee Mon Apr 18, 2022 8:34 pm
Yes its there ok. This doesn't mean that makes sense UI wise to be there. As I come from c4d, I use dome/sky lights for environment.
RS uses also the same concept in Houdini, has dome lights. Having lights in render settings is weird.
Now if it's not possible that's another story.
I spent 2 hours last night trying to add a single color in the environment without success. Could you please add that option there at least?
thanulee
Re: Dome light
Postby trogers » Wed Oct 05, 2022 2:53 am
trogers Wed Oct 05, 2022 2:53 am
Here's an easy workaround:
In the Img context create a Comp node if none exists. Create a color node inside. Select the color node and copy it to the clipboard. Then in your Octane Render Target in the TEXT Environment tab paste the path into the Texture filename param field. Put op: in front of the path. It should look something like this op:/img/comp1/color1
Now you should be able to adjust the color of the environment. For best results keep the Power to between 0 and 1.
Win 10 / AMD 3970x / Nvidia 4090 + 2080 Ti / 128GB
trogers
Return to User Requests
Sat Apr 27, 2024 12:54 am [ UTC ]
