Before posting a bug report, please check the following: 1. That the issue has not already been disclosed 2. That the issue is specific to this plugin, and not Octane in general (Try reproducing it in Standalone) Bugs related to the Octane Engine itself should be posted into the Standalone Support sub-forum.
All bug reports should include the information below, along with a detailed description of the issue and steps to reproduce it. A. Operating System, including version (i.e. Win 7, OSX 10.11.2, Ubuntu 14.04, etc.) B. Graphics Card(s) model (i.e. GTX 580 - 3GB, TITAN, etc.) C. RAM Capacity (i.e. 6 GB) D. Nvidia driver version (i.e. 7.50, 7.5.22) E. OctaneRender Standalone version, if installed (i.e. 2.24.2, 2.23, etc.) F. OctaneRender plugin version (i.e. v2.25 - 2.21) G. Host application version, including build number if available (i.e. 3ds Max 2016 Build 18.0)
I'm having issues getting both Axiom and Octane to load. If I comment out the 3 lines of code that load Octane in the ENV file it will load. Octane works but it doesn't load axiom if enabled.
This is usually a problem in the houdini.env configuration file. You must define a single environment variable to include all the plugin paths separated by semicolons. The definition of the same variable twice or more doesn't work.
