Geometry missing from render
Forums: Geometry missing from render
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby lionlee19 » Mon May 02, 2022 8:54 am
lionlee19 Mon May 02, 2022 8:54 am
I have encountered this bug multiple times now.
"Render frame range" is buggy.
Octane will not read in the geometry data if the data only start appear in the middle of the sequence.
For example, I have a geo object named "A" which only has polygon from Frame10 onward.
If I "save render as frame range " from Frame1 to Frame20, because "A" has nothing on the starting frame, Octane will be bugged and render the whole sequence without A.
But if I "save render as frame range " from Frame10 to Frame20, because "A" has geometry data on the starting frame, A will be rendered correctly and apear throughout the whole sequence.
lionlee19
Re: Geometry missing from render
Postby juanjgon » Mon May 02, 2022 4:06 pm
juanjgon Mon May 02, 2022 4:06 pm
Yep, this is a known limitation. If an OBJ node doesn't have any valid geometry in the first frame, it is not even extracted, so later it can't be updated.
The workaround for this kind of scene is to render them in full scene reload mode. If you configure the Octane ROP node to render in full scene reload mode, the whole sequence should be rendered fine.
juanjgon
Postby mirocreative » Thu May 05, 2022 2:15 pm
mirocreative Thu May 05, 2022 2:15 pm
I had this issue when working with particles not being present on the first frame. I placed a few particles behind the camera (at a blind spot) and managed to render/export without the frame range madness. Might work for you as well.
mirocreative
Postby Carlll » Tue Jun 06, 2023 9:59 pm
Carlll Tue Jun 06, 2023 9:59 pm
juanjgon wrote:Yep, this is a known limitation. If an OBJ node doesn't have any valid geometry in the first frame, it is not even extracted, so later it can't be updated.
how is this a thing with the octane plugin but works fine with the redshift houdini plugin? you worked on both right so im curious why they differ when it comes to this feature/issue?
Carlll
Return to Bug Reports
Who is online
Users browsing this forum: No registered users and 2 guests
Sun May 12, 2024 11:03 pm [ UTC ]
