18.5 FX Material Trying to switch to Limited Commerical
Forums: 18.5 FX Material Trying to switch to Limited Commerical
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby liamclisham » Fri Nov 27, 2020 4:12 pm
liamclisham Fri Nov 27, 2020 4:12 pm
I just installed the latest build for 18.5 and everything works up until I try to create a material. When I go into the Octane Material Builder and hit tab to put down some nodes, I immediately get an error that it's trying to switch to limited commercial mode. Here is a screen shot: https://i.imgur.com/L2HY3p8.png. I've never had this issue before with previous versions of Houdini. Did something change or is this a bug?
liamclisham
Re: 18.5 FX Material Trying to switch to Limited Commerical
Postby juanjgon » Fri Nov 27, 2020 4:29 pm
juanjgon Fri Nov 27, 2020 4:29 pm
Hmm, I had never seen anything like that. Are you sure that you don't have in your system (for example in your $HOME/otls folder) HDAs created using the Indie or Apprentice versions?
juanjgon
Return to Bug Reports
Fri Apr 26, 2024 9:19 am [ UTC ]
