OSL in Houdini with liveDB
Forums: OSL in Houdini with liveDB
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby efxlab » Tue Apr 14, 2020 9:23 am
efxlab Tue Apr 14, 2020 9:23 am
Hey, I can't figure how import a OSL script in houdini, drag and drop doesn't work !
Using Octane 2020 RC2
Windows 10 - GTX 1060 6GB
Houdini 18 DCC plugin
efxlab
Re: OSL in Houdini with liveDB
Postby juanjgon » Tue Apr 14, 2020 11:04 am
juanjgon Tue Apr 14, 2020 11:04 am
The OSL VOP nodes accept both an input file or the OSL code embedded in the node text editor. Doesn't it work for you?
juanjgon
Postby efxlab » Tue Apr 14, 2020 12:24 pm
efxlab Tue Apr 14, 2020 12:24 pm
I dont understand ? how I move the OSL utility shader from LiveDB in houdini ?, Copy take a XML htmlentities text, not well formated for OSL node. Drag and drop no work, and the import button does nothing
efxlab
Postby juanjgon » Tue Apr 14, 2020 6:26 pm
juanjgon Tue Apr 14, 2020 6:26 pm
Ah, sorry. Yes, true. Currently, you can't download these OSL textures directly in the Houdini plugin because it only supports material type liveDB nodes. I'll take a look at this limitation at some point, but meanwhile, you could open the liveDB OSL texture in the Standalone and copy/paste the OSL code into the plugin OSL VOP node, as you can see in the attached images.
juanjgon
Return to Bug Reports
Users browsing this forum: No registered users and 7 guests
Sat Apr 27, 2024 2:58 am [ UTC ]
