IPR camera resolution proportions
Forums: IPR camera resolution proportions
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Postby WhyGee » Fri Nov 18, 2016 8:23 pm
WhyGee Fri Nov 18, 2016 8:23 pm
When I render in IPR and have a camera for example with square proportions, it doesn't seem to frame the image correctly. If I render the final image it looks correct.
Any ideas?
Yaniv
WhyGee
Re: IPR camera resolution proportions
Postby juanjgon » Sat Nov 19, 2016 10:39 am
juanjgon Sat Nov 19, 2016 10:39 am
The first time you open the IPR window, it should have the correct image proportions from the camera resolution. If you scale the window you can lose the proportions, but two horizontal red lines should mark the camera limits.
If you want to open always the IPR with the camera proportions, even after scale it, you can configure the IPR Window Size in Camera mode. You have even an option to set the camera resolution multiplier for the IPR. All these options are in the plugin options panel, IPR tab.
juanjgon
Return to Bug Reports
Sat Apr 27, 2024 8:21 pm [ UTC ]
