ricky_otoy wrote:lavrenovlad wrote:Also what was the point of trying to change the ROP node with all these additional options if it still not clear how one can export PNGs with ACEScg baked in as sRGB? All I can see some new buttons that don't improve functionality, everything works as bad as before
As I mentioned on the other thread to you, we can't reproduce the crash with the denoiser - but may be a standalone issue. Do you get a crash there with your scene?
As for ACES, you shouldn't really have to do anything special. Use the defaults and if you are using OCIO then choose the appropriate role when saving out your PNG or PNG 16bit through ROPS. Such as:
- Code: Select all
color_picking
Color spaces / Output / Output - sRGB
etc.
That should give you the same result if you are using the view transform for IPR such as "ACES: sRGB"
lavrenovlad wrote:Something wrong with denoisers in this version. Using them causes "crashes" on my end, sometimes IPR just freezes and I need to restart Houdini. Might be a core issue I don't know, I hope it will be fixed in the next build.
Users browsing this forum: No registered users and 5 guests
