OctaneRender™ 2018.1 for Houdini™ beta build 2018.1.0.3 RC3
Forums: OctaneRender™ 2018.1 for Houdini™ beta build 2018.1.0.3 RC3
Re: OctaneRender™ 2018.1 for Houdini™ beta build 2018.1.0.3 RC3
Postby juanjgon » Wed Feb 06, 2019 10:02 pm
juanjgon Wed Feb 06, 2019 10:02 pm
zbynekkrulich wrote:Hey Juanjo,
thanks
I put NVLINK to test and it seams that octane crashes when I hit the VRAM capacity of one card - is VRAM pooling one of the features?
I simply created high-poly geo ... do you have any better idea to test if it is working, pls?
54093&hilit=nvlink#p354093
To be honest, I'm not even sure if this feature is exposed in the plugins yet. Do you know what happens with Standalone if you try to render a huge scene? You could try to export it from Houdini using the scene exports functions.
juanjgon
Postby juanjgon » Wed Feb 06, 2019 10:03 pm
juanjgon Wed Feb 06, 2019 10:03 pm
k3nny wrote:Yes its the octane OpenSubdiv feature.Any idea when this update is going to be released?
Thanks for the prompt reply.
The team is working hard to have it ready as soon as possible. It should be a matter of a few days.
juanjgon
Postby Hampayon » Thu Feb 07, 2019 6:16 am
Hampayon Thu Feb 07, 2019 6:16 am
. Fixed an issue on Linux causing the computer to be identified differently if Houdini+Hython is being used. As a result a second license would have been required if Octane was
already run as Standalone or as different plugin.
Big thanks for this!
Hampayon
Postby zbynekkrulich » Sun Feb 10, 2019 6:35 pm
zbynekkrulich Sun Feb 10, 2019 6:35 pm
hey, ok, no problem - goldorak wrote it here viewtopic.php?f=33&t=69461
Unfortunately I can't test it in standalone since export from Houdini is locked due Indie version restrictions and standalone Octane can't see my license. I have Annual All-access subscription. Ehm
Best
zbynek
zbynekkrulich
Postby ptunstall » Tue Feb 12, 2019 6:00 am
ptunstall Tue Feb 12, 2019 6:00 am
For both RC1 and RC3 I get this error in my linux shell when I try to connect to slaves:
CUDA error 700 on device 0: an illegal memory access was encountered
-> failed to deallocate device memory
I've tried nvidia and libcuda1 drivers 410.78 and 415.27 in linux. Do I need to use something newer than this?
I do not have this issues with your latest release of 4.
ptunstall
Postby juanjgon » Tue Feb 12, 2019 4:09 pm
juanjgon Tue Feb 12, 2019 4:09 pm
ptunstall wrote:For both RC1 and RC3 I get this error in my linux shell when I try to connect to slaves:
So do you get this error on the slaves, or in the main Houdini session when you try to use the network rendering feature?
juanjgon
Postby ptunstall » Tue Feb 12, 2019 11:02 pm
ptunstall Tue Feb 12, 2019 11:02 pm
This is the error I receive in the linux shell on the slave machines. Locally houdini/octane works fine in both RC1and RC3.
ptunstall
Postby WhyGee » Tue Feb 26, 2019 10:52 am
WhyGee Tue Feb 26, 2019 10:52 am
I seem to be having trouble with cryptomattes generating random values for each frame. I've tried using all cryptomatte passes types but none seem to be consistent throughout the animation. Am I do something wrong?
Yaniv
WhyGee
Postby juanjgon » Wed Feb 27, 2019 10:12 pm
juanjgon Wed Feb 27, 2019 10:12 pm
WhyGee wrote:Hi,
This problem can be related to the multi-thread scene extraction feature. If it is enabled the objects extraction order can change among the frames, and with it all the object and material IDs, so I'm afraid that you need to disable this option to render cryptomatte passes in animated sequences.
juanjgon
Postby WhyGee » Thu Feb 28, 2019 8:21 am
WhyGee Thu Feb 28, 2019 8:21 am
great thanks alot!
WhyGee
Previous
Return to Releases
Fri Apr 26, 2024 3:46 pm [ UTC ]
