Cant render out frame range
Forums: Cant render out frame range
Houdini Integrated Plugin
Postby fl4mingo » Sun Jan 07, 2024 5:39 am
fl4mingo Sun Jan 07, 2024 5:39 am
Hello,
I have been trying to render out a frame range of my FLIP sims white water and every time I try it gives me a black file.
I have the file split up to have the wave geo as one layer and the WW as its own, the wave geo worked perfectly fine when I rendered out it as a frame range.
It works normally when I view it in the IPR and if I do it as an individual frame so I don't think its an issue with my OCIO config.
So far I have tried:
- Deleting the Octane ROP
- Copying everything to a new file
- Disabling motion blur
- Disabling denoising
Any help would be appreciated!
fl4mingo
Re: Cant render out frame range
Postby galleon27 » Sun Jan 07, 2024 11:19 am
galleon27 Sun Jan 07, 2024 11:19 am
You probably don't have any geometry in the first frame. Try rendering when there's already something in the shot or add a single point and merge it with the geometry.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Postby fl4mingo » Sun Jan 07, 2024 6:42 pm
fl4mingo Sun Jan 07, 2024 6:42 pm
that did the trick thank you! I guess it was only emitting the particles on frame 2 so moving the range over one fixed it.
fl4mingo
Return to Houdini
Who is online
Users browsing this forum: Bing [Bot] and 27 guests
Sat Apr 27, 2024 7:01 am [ UTC ]
