Octane scatter CD attrib
Forums: Octane scatter CD attrib
Houdini Integrated Plugin
Postby thanulee » Sat Dec 16, 2023 4:45 pm
thanulee Sat Dec 16, 2023 4:45 pm
Can you point me out on how to grab the Cd attrib on octane scatter? Or that is not possible?
Ty
thanulee
Re: Octane scatter CD attrib
Postby ricky_otoy » Sun Dec 17, 2023 11:43 am
ricky_otoy Sun Dec 17, 2023 11:43 am
Hi thanulee,
I will double-check tomorrow, but as far as I know, the Cd attribute isn't supported using the Octane Scatter.
What you can do for the moment is get the Cd attribute information on Packed geo instancing - a 'Texture Instance Color' in the material pointing to the "rgb4k_map.ppm" or alpha with "alpha4k_map.ppm". SOP obj Octane properties "Instance ID's from" needs to be set to Packed RGBA values from Çd' point attribute.
If you don't need it packed, then you can use the 'color vertex attribute' with Cd. Just don't forget to add the attribute on the SOP object under Octane / Attributes / Point Vector Attrs.
ricky_otoy
Postby thanulee » Sun Dec 17, 2023 2:04 pm
thanulee Sun Dec 17, 2023 2:04 pm
Thanks, yes I know the other ways, was wondering specifically about octane scatter.
Let me know if that is possible! thanks
thanulee
Return to Houdini
Who is online
Users browsing this forum: No registered users and 17 guests
Sat Apr 27, 2024 8:51 pm [ UTC ]
