Comign from Redshift - Ramp Node Equivalent?
Forums: Comign from Redshift - Ramp Node Equivalent?
Houdini Integrated Plugin
Postby RyanJP » Mon Nov 27, 2023 4:34 pm
RyanJP Mon Nov 27, 2023 4:34 pm
Hi is there a simple way to run a texture through ramp like in Redshift? Looking for a way to quickly remap colors/levels. Thanks
RyanJP
Re: Comign from Redshift - Ramp Node Equivalent?
Postby vurt » Mon Nov 27, 2023 11:09 pm
vurt Mon Nov 27, 2023 11:09 pm
it's called "gradient" in Octane, at least in Houdini plugin. Need to get used to the name yeah, I still sometimes search for ramp and can't find it :mrgreen:
vurt
Postby RyanJP » Tue Nov 28, 2023 1:58 am
RyanJP Tue Nov 28, 2023 1:58 am
vurt wrote:Hi,
Thanks.. it still doesn't really behave the way I'd expect. Seems like the image adjust node is the way to go for simple levels manipulation, just seems like overkill and also the node is awkwardly large. Ah well, most everything else is better in Octane
RyanJP
Postby ricky_otoy » Tue Nov 28, 2023 8:06 am
ricky_otoy Tue Nov 28, 2023 8:06 am
RyanJP wrote:
vurt wrote:Hi,
The gradient node has been fixed, it should behave in a way you are probably much more accustomed to - should in the next update.
ricky_otoy
Postby elsksa » Tue Nov 28, 2023 1:47 pm
elsksa Tue Nov 28, 2023 1:47 pm
Worth mentioning the Range node as well. Depending on someone's intentions.
elsksa
Postby RyanJP » Tue Nov 28, 2023 3:26 pm
RyanJP Tue Nov 28, 2023 3:26 pm
ricky_otoy wrote:The gradient node has been fixed, it should behave in a way you are probably much more accustomed to - should in the next update.
Oh that's great news, thanks!
RyanJP
Return to Houdini
Users browsing this forum: No registered users and 25 guests
Sat Apr 27, 2024 7:18 pm [ UTC ]
