Installation on OSX
Posted: Wed Sep 27, 2023 7:16 pm
I'm trying to install Octane for Houdini on my Macbook Max Houdini 19.5.716
I have downloaded Octane_2022.1.2.0_Houdini_macos_Prime
I have it installed at /Users/<USER>/Library/Preferences/houdini
I have unzipped all three folders.
My Houdini.env is:
# NOTE: The use of packages is highly recommended instead of houdini.env
# See details about packages here: https://www.sidefx.com/docs/houdini19.5 ... ugins.html
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_DSO_ERROR = 2
HOUDINI_PATH = "/Applications/redshift/redshift4houdini/19.5.368;&"; "/Users/<USER>/Library/Preferences/houdini/Octane_2022.1.2.0_Houdini_macos_Prime/;&"
My Houdini.env is:
# the environment.
# VAR = VALUE
# VAR = "VALUE"
# VAR =
# Example:
