I have my packages environment etc. saved (Win 11) Users/documents/houdini_HVER_ I also have this environement variable set under windows.
For some reason Octane errors when I try and save a new octane.pref as it wants to save it in the directory Users/OneDrive/documents/houdini(version)
I can manually create this directory as a work around and I do indeed see the octane pref there but I would like it to respect the same path as everything else in Houdini is using for the prefs folder, do you know how I can fix this? Is there an environment variable specifically for OCtane?
Originally I had a user with online login but since then I have deleted thagt user and made a local user + re-installed Octane and Houdini yet somehow the Octane pref wants to save in that old non existant path.
