Animation Frames are black
Forums: Animation Frames are black
Houdini Integrated Plugin
Postby gopper0815 » Mon Dec 26, 2022 6:30 pm
gopper0815 Mon Dec 26, 2022 6:30 pm
Hello,
i setup a particle simulation. When i look at ipr, all is good. When i render a single frame from the simulation (it doesn´t matter, wicht frame) all is good. But when i render a framrange from 1 to 40, all frames are complete black. Where is my mistake? It render also too fast. So as there is no information to render. When i render a single frame, it took about 10 seconds per frame. When i render animation, it took one second per frame
gopper0815
Re: Animation Frames are black
Postby galleon27 » Mon Dec 26, 2022 8:55 pm
galleon27 Mon Dec 26, 2022 8:55 pm
You have to have at least one particle spawned in frame 1 in order for the sequence to render. You can just render from whatever frame the particles are first spawn and your gonna be just fine.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Postby gopper0815 » Tue Dec 27, 2022 4:51 am
gopper0815 Tue Dec 27, 2022 4:51 am
Thank you very much, that works.
gopper0815
Postby juanjgon » Tue Dec 27, 2022 10:44 am
juanjgon Tue Dec 27, 2022 10:44 am
Yes, sorry. This is a known limitation. Any objects without geometry or particles are filtered by the plugin and excluded from the Octane scene. If this happens in the first frame, later the plugin can't update them.
juanjgon
Return to Houdini
Users browsing this forum: pxlntwrk and 7 guests
Tue May 21, 2024 11:48 am [ UTC ]
