Render to disk not working
Forums: Render to disk not working
Houdini Integrated Plugin
Postby chris_VFX » Tue Aug 09, 2022 3:49 pm
chris_VFX Tue Aug 09, 2022 3:49 pm
Hi !
I have a problem with Octane, i render a simple animation with smoke, instances and a some debris,
when i hit ipr render it took 19 sec to render(30 sec max with the pre-loading) and my memory grow up to 28 Go, but if i hit render to disk....it's so long to render maybe 30 minutes and more and my memory saturated 65Go/65Go.....
Have you any ideas ? What's happened ? Thanks a lot !! :)
Houdini 19.0.657 & Octane 2021.1.0.4
chris_VFX
Re: Render to disk not working
Postby juanjgon » Tue Aug 09, 2022 4:14 pm
juanjgon Tue Aug 09, 2022 4:14 pm
It is hard to say what could be the problem without more information. Can you please share the scene file? Have you tried the latest Octane 2021.1.5.0 plugin builds?
juanjgon
Postby chris_VFX » Tue Aug 09, 2022 4:55 pm
chris_VFX Tue Aug 09, 2022 4:55 pm
My scene load a multiples filecaches, it' so complex i think to share.
I think the problem are my Smoke, if i disable the smoke the render works again, it's take a while to loading my 2 smoke sim, i have at the end a filecache and pyrobakevolume and a material.
Per frame i takes 1.44Go + 350 Mo of cache on my disk.(35Go each simulation for 85 Frames)
How can i optimize my cache ? 2 Go of smoke are too big ?
Thanks. :)
chris_VFX
Postby juanjgon » Tue Aug 09, 2022 5:25 pm
juanjgon Tue Aug 09, 2022 5:25 pm
You should cache your volume objects as OpenVDB files that Octane can load at the render time if you configure them from the "OpenVDB" tab in the Octane OBJ spare parameters. The extraction of the volumes data directly from Houdini can be slow and it could need a lot of RAM for large volumes.
juanjgon
Postby chris_VFX » Tue Aug 09, 2022 7:29 pm
chris_VFX Tue Aug 09, 2022 7:29 pm
Thanks, i have combined a compress volume saved in VDB and i have load the file with your process and it's good ! much faster.
Thanks a lot ;)
chris_VFX
Return to Houdini
Who is online
Users browsing this forum: No registered users and 20 guests
Sat Apr 27, 2024 7:17 am [ UTC ]
