Bump cut-off at a certain distance
Forums: Bump cut-off at a certain distance
Houdini Integrated Plugin
Postby litesound » Wed Sep 08, 2021 2:23 pm
litesound Wed Sep 08, 2021 2:23 pm
Octane disables bump effect at a certain distance from the origin, approximately 1500 units. Is it possible to keep the bump on the whole geometry instead without being tied up to the distance from the origin?
litesound
Re: Bump cut-off at a certain distance
Postby juanjgon » Wed Sep 08, 2021 3:12 pm
juanjgon Wed Sep 08, 2021 3:12 pm
Have you tried to adjust the ray epsilon parameter in the kernel node?
juanjgon
Postby litesound » Wed Sep 08, 2021 4:11 pm
litesound Wed Sep 08, 2021 4:11 pm
yes unfortunately it didn't help this time
litesound
Postby juanjgon » Wed Sep 08, 2021 4:33 pm
juanjgon Wed Sep 08, 2021 4:33 pm
If you can share the scene, or an .orbx file exported from it or from the IPR window, I could report this issue to the core devs to check if something can be done to fix it.
juanjgon
Postby litesound » Wed Sep 08, 2021 4:47 pm
litesound Wed Sep 08, 2021 4:47 pm
Thank you,
here is the file
procedural bump issue.rar
(38.16 KiB) Downloaded 74 times
litesound
Return to Houdini
Users browsing this forum: No registered users and 17 guests
Fri Apr 26, 2024 4:08 pm [ UTC ]
