Instancing Picks up Original Object Transform
Forums: Instancing Picks up Original Object Transform
Houdini Integrated Plugin
Postby HBHATTI » Sat Jun 19, 2021 10:25 am
HBHATTI Sat Jun 19, 2021 10:25 am
I have a sphere object I created and applied a transform to it in my geometric modeling process, when I instanced the object, it appears to be picking up part of some of the original transform? I have applied a pscale attribute which I have then randomized it. Could this be partially affecting it? Am including an attached hip file
instancing.zip
(40.38 KiB) Downloaded 94 times
HBHATTI
Re: Instancing Picks up Original Object Transform
Postby juanjgon » Mon Jun 21, 2021 10:54 am
juanjgon Mon Jun 21, 2021 10:54 am
If you apply a transformation at the SOP level you are indeed modifying the shape. This is a modeling operation, so yes, this transformation will also be used by the instances.
juanjgon
Postby HBHATTI » Mon Jun 21, 2021 11:39 am
HBHATTI Mon Jun 21, 2021 11:39 am
Thank you for the help, I am inside the geometry node and applying transforms at that level
HBHATTI
Return to Houdini
Users browsing this forum: No registered users and 17 guests
Fri Apr 26, 2024 2:53 pm [ UTC ]
