Render Region+ material update saves out noisy render
Forums: Render Region+ material update saves out noisy render
Houdini Integrated Plugin
Postby WoutTgh » Thu Apr 09, 2020 4:16 am
WoutTgh Thu Apr 09, 2020 4:16 am
when you render region in ipr and update a material setting, the ipr window renders the region correctly and leaves the previous render outside the region as it was. The saved export file renders out a super noisy render. I'm guessing the ipr window doesn't update outside the region but the render buffer does ?
WoutTgh
Re: Render Region+ material update saves out noisy render
Postby juanjgon » Sun Apr 12, 2020 5:14 pm
juanjgon Sun Apr 12, 2020 5:14 pm
Yes, I think that the problem is something like that. The IPR window stores on the plugin side the full-frame rendered image inside the OpenGL buffer, but the internal Octane buffer that is used while saving images from the IPR doesn't have this behavior.
juanjgon
Postby WoutTgh » Sun Apr 12, 2020 9:16 pm
WoutTgh Sun Apr 12, 2020 9:16 pm
OKay, it would be nice to to able to render regions of the frame and save out the render as shown in the IPR window :)
WoutTgh
Return to Houdini
Who is online
Users browsing this forum: No registered users and 8 guests
Sun Apr 28, 2024 1:19 am [ UTC ]
