plugin 3.00.0.1 liveDB freeze on import
Forums: plugin 3.00.0.1 liveDB freeze on import
Houdini Integrated Plugin
Re: plugin 3.00.0.1 liveDB freeze on import
Postby juanjgon » Mon Feb 01, 2016 11:08 am
juanjgon Mon Feb 01, 2016 11:08 am
Let me think about it. I need to test how the Houdini ramp data is used inside the plugin.
juanjgon
Postby Stassius » Sun Feb 14, 2016 4:06 pm
Stassius Sun Feb 14, 2016 4:06 pm
Hello! Any update on this problem? LiveDB and LocalDB are still not working on 3.0.0.4
Is there another way to convert material from Stand Alone?
Stassius
Postby juanjgon » Sun Feb 14, 2016 4:41 pm
juanjgon Sun Feb 14, 2016 4:41 pm
I want to release a new plugin version soon that should have this problem fixed.
What version of Houdini and what OS are you using? I can send to you a custom build with this problem fixed to test it.
juanjgon
Postby Stassius » Sun Feb 14, 2016 6:00 pm
Stassius Sun Feb 14, 2016 6:00 pm
Houdini 15.0.347, Windows 7
Thank You!
Stassius
Postby juanjgon » Mon Feb 15, 2016 9:46 am
juanjgon Mon Feb 15, 2016 9:46 am
Please, test this build to know how it works now. Thanks.
https://render.otoy.com/customerdownloa ... _Win64.zip
juanjgon
Postby Stassius » Mon Feb 15, 2016 10:03 am
Stassius Mon Feb 15, 2016 10:03 am
Yes, LiveDB works now. Thanks!
Stassius
Postby Stassius » Mon Feb 15, 2016 10:14 am
Stassius Mon Feb 15, 2016 10:14 am
Nope, i was wrong. First material imports without problems. When i try to import second one (no matter which), Houdini crashes. So it works only for a first import in a scene. Checked a couple of times with different materials.
Stassius
Postby juanjgon » Mon Feb 15, 2016 11:20 am
juanjgon Mon Feb 15, 2016 11:20 am
True, it has a second bug that should be fixed now. Please, try this new build.
Thanks for reporting,
juanjgon
Postby Stassius » Mon Feb 15, 2016 11:33 am
Stassius Mon Feb 15, 2016 11:33 am
Yes, it works. Thank you!
One feature request.
Some materials in LiveDb have parameter naming. For example MBB_Quixel_PBR have names for maps (albedo etc).
After import to Houdini it becomes a mess of nodes without proper naming.
It would be great to inherit node names from LiveDB.
Stassius
Previous
Return to Houdini
Wed May 22, 2024 1:46 pm [ UTC ]
