Instanced geo on 500K particles - ipr wont load
Forums: Instanced geo on 500K particles - ipr wont load
Houdini Integrated Plugin
Postby OuterGamut » Mon May 16, 2022 3:53 am
OuterGamut Mon May 16, 2022 3:53 am
I'm having some hangups with octane instancing - the ipr basically stalls out when trying to preview the instanced geo.
There is about 540k+ points with orient, pscale and v on them. The geo has about 500 faces. @instancepath is setup to point at a null in the same obj sop.
I have not been able to get an image to load up on a 3090. Any advice or best practices to make this work?
The instance node previews some of the instanced geo then fades into bboxes so the path seems to be working.
OuterGamut
Re: Instanced geo on 500K particles - ipr wont load
Postby mirocreative » Wed May 18, 2022 5:57 am
mirocreative Wed May 18, 2022 5:57 am
Instead of @instancepath did you try using the s@instance option using a wrangle? Usually works much better for me than anything else.
If you can upload the base scene, I'll check what happens with 2x3090.
mirocreative
Return to Houdini
Users browsing this forum: Bing [Bot] and 21 guests
Fri Apr 26, 2024 1:11 am [ UTC ]
