Open Live DB not opening tab
Forums: Open Live DB not opening tab
Discussion forum for OctaneRender Cloud
Postby SpiroBunster » Sun Jan 29, 2023 11:04 pm
SpiroBunster Sun Jan 29, 2023 11:04 pm
Hi! I am having problem opening the tab of the "Open Live DB" in Octane because it doesn't appear, it's the only tab that doesn't open, for example if I click on the "Octane Node Editor" it appears inmediately, but not with the Open LiveDB.
Somebody knows what could be, or there is another way to open that tab?
Thank you so much! :)
SpiroBunster
Re: Open Live DB not opening tab
Postby bepeg4d » Thu Feb 02, 2023 7:03 am
bepeg4d Thu Feb 02, 2023 7:03 am
ok, to share which version you are using exactly, please go to c4d menu Script/Console or Extensions/Console, (Shift+F10), and copy paste the default console output in your answer, thanks.
ciao,
Beppe
Postby SWPMediaUnit » Fri Feb 17, 2023 2:26 pm
SWPMediaUnit Fri Feb 17, 2023 2:26 pm
Hi! This has just started happening to me too. All was fine, but now when clicking on open live db nothing happens!
Using Cinema 4D 2023.1.3 (Build 2023.CL390584.49583)
Octane macOS 2022.1
Running on Macbook Pro M1 Max on Venture 13.2
SWPMediaUnit
Postby bepeg4d » Tue Feb 28, 2023 7:12 am
bepeg4d Tue Feb 28, 2023 7:12 am
Sorry, LiveDB is not available in OctaneX 2022.1.
It will come back with future 2023.1 version.
ciao,
Beppe
Postby jaykats » Fri Mar 24, 2023 2:38 pm
jaykats Fri Mar 24, 2023 2:38 pm
Greetings,
I am running into the same issue! Do you have an estimation on when the 2023.1 version will be available?
Thank you for your time!
Kind regards,
Jay
jaykats
Postby JamesSamson » Fri Mar 31, 2023 9:44 am
JamesSamson Fri Mar 31, 2023 9:44 am
I also want to know when 2023.1 version will be available?
JamesSamson
Postby GJs » Fri Oct 20, 2023 11:51 pm
GJs Fri Oct 20, 2023 11:51 pm
Live DB appears not to be working in 2023.1?
All the best
Dave
GJs
Postby bepeg4d » Mon Oct 23, 2023 6:39 am
bepeg4d Mon Oct 23, 2023 6:39 am
Yes, 2023.1 is out:
viewtopic.php?f=85&t=82234
But LiveDB is going to arrive with upcoming 2024.1 version.
For now, please have a look at this workaround:
viewtopic.php?f=7&t=75411&start=1520
ciao,
Beppe
Return to OctaneRender Cloud
Users browsing this forum: No registered users and 23 guests
Sun Apr 28, 2024 7:13 am [ UTC ]
