Importing obj file with transparent material
objo
I am making an open source exporter (.net/WPF) that creates obj files for import in Octane.
Diffuse materials and geometry works great, but I don't get Octane to import the specular components and opacity of my simple materials.
Here is an example I would expect to show two diffuse/specular/transparent planes:
test1.mtl
newmtl PlaneMaterial
Kd 1.0 0.0 0.0
Ks 0.4 0.4 0.4
d 0.5
illum 2
test1.obj
mtllib test1.mtl
o Planes
v 1 0 -1
v 1 0 1
v -1 0 1
v -1 0 -1
v 1 0.1 -1
v 1 0.1 1
v -1 0.1 1
v -1 0.1 -1
vn 0 1 0
usemtl PlaneMaterial
s off
f 1//1 4//1 3//1 2//1
f 5//1 8//1 7//1 6//1
Is something wrong here?
I use default OBJ mesh import preferences, both "Diffuse" and "Specular" material types are checked.
I have tried using both "Tr" and "d" in the mtl file.
face
Diffuse: Specular Decay = 0 or Specular Color = black
Specular: Index Of Refraction > 1 and Transparancy Color > black
Glossy: All other possible options
hope this helps...
face
http://vimeo.com/user2509578
t_3
... here is a working example (glossy), including bump & opacity maps:
Plane.obj:
mtllib Plane.mtl
o Plane
v 0 0 1
v 1 0 1
v 0 0 0
v 1 0 0
vt 0 0
vt 1 0
vt 0 1
vt 1 1
vn 0 1 0
vn 0 1 0
vn 0 1 0
vn 0 1 0
g Plane
usemtl Default
f 1/1/1 2/2/2 4/4/4 3/3/3
Plane.mtl:
newmtl Default
Ns 1
Kd 1 0 0
Ks 0 0 1
Km 1
map_D /Maps/dummy.jpg
map_Bump /Maps/dummy.jpg
and another .mtl for specular:
Plane.mtl:
newmtl Default
Ns 1
Ni 2
Kd 1 0 0
Ks 0 0 1
or in other words, you're missing the "Ni" - index of refraction - and opacity only works through an applied map (but i'm maybe wrong here)...
The obvious is that which is never seen until someone expresses it simply
Tugpsx
nice find
objo
Thanks for your replies!!
I have specular materials working now, but still have problems with opacity.
Specular materials: I see there is a difference when I specify Ni or not:
if I specify Ni, I get a specular material with Reflection (Ks) and Transmission (Kd) components.
if I do not specify Ni, I get a glossy material with Diffuse (Kd) and Specular (Ks) components.
Opacity: I also tried setting the dissolve map (map_D), but can't get this imported. There is also no effect of the dissolve parameter (d). The "Texture types|opacity (d)" is checked under preferences. Diffuse and bump maps are imported ok. Are there any other parameter I have to set?
The following is from the obj spec
map_d -options args filename
Specifies that a scalar texture file or scalar procedural texture file
is linked to the dissolve of the material. During rendering, the map_d
value is multiplied by the d value.
"filename" is the name of a scalar texture file (.mps), a scalar
procedural texture file (.cxs), or an image file.
The options for the map_d statement are listed below. These options
are described in detail in "Options for texture map statements" on page
5-18.
-blendu on | off
-blendv on | off
-clamp on | off
-imfchan r | g | b | m | l | z
-mm base gain
-o u v w
-s u v w
-t u v w
-texres value
and
d factor
Specifies the dissolve for the current material.
"factor" is the amount this material dissolves into the background. A
factor of 1.0 is fully opaque. This is the default when a new material
is created. A factor of 0.0 is fully dissolved (completely
transparent).
Unlike a real transparent material, the dissolve does not depend upon
material thickness nor does it have any spectral character. Dissolve
works on all illumination models.
t_3: Thanks for your examples! I don't get the dissolve map to import, does it work on your machine?
(I am using 1.0beta 2.46b demo)
t_3
the examples work here - with 2.55b; could, be that it really is different to 2.46. i remember, that around 2.49 the import was corrected, so that "map_d" and "map_D" would work, so maybe opacity import was not working at all (earlier).
the "d" is completely ignored, but i don't know why (haven't missed it that much though)...
objo
ok, that makes a good reason to upgrade to the full version :)
I hope support for the "d" value can be implemented soon!
t_3
objo wrote:ok, that makes a good reason to upgrade to the full version :)
this seems to be the most uncommon reason ever to buy octane :lol:
but as you get pmc, sss & speed improvements as well, you won't regret it imo...
