by frifer » Tue May 19, 2015 12:08 pm
frifer
here we go!
there are 3 cubes! first one is a solid, second is a surface with transparency disabled, third one is a surface with transparency enabled.
when files have a problem importing they convert to surfaces. (about 70% of the files have problems importing..) sometimes they can be converted to solids in a few minutes by plugging the holes and copying the surfaces to a new solid. but most of the time there are so many problems that it takes hours so its easier to simply disable transparency and do as if it would have been a normal solid.
- cubes.zip
- (104.11 KiB) Downloaded 950 times
