				Lightwave animation workflow
				Posted: Wed Oct 12, 2011 10:57 am
				by marchermitte
				Hello! I'm trying to setup a simple animation from lightwave to Octane and It doesn't seem to work... what's the workflow / workaround?  I'd like to animate not only the camera but also some meshes (no vertex deformation, only mesh moving around) Can anyone advise me?
Thank you!
				Re: Lightwave animation workflow
				Posted: Wed Oct 12, 2011 2:15 pm
				by scratch33
				Hello,
You must set the animation in lightwave, then setup the octane exporter plugin like you setup for one picture.
Finaly you push the "render animation".
The problem is that if you have a change in the scene( including mesh moving), the plugin must send the scene to octane for every frame...
And depend on your scene... This can take a very long time...
				Posted: Wed Oct 12, 2011 4:51 pm
				by marchermitte
				Ok, until now I tested with just a basic cube anim and a plane... and It takes forever, actualy It looks like It crashed. It would be much better to use MDD file (vertex displacement infos) or the equivalent for 3Dmax and Maya, Geocache I think. This way you import the obj and apply MDD in the scene, no need to export anim from the native application for each frame.
				Posted: Wed Oct 12, 2011 8:22 pm
				by scratch33
Try in fast mode. The normal mode is too slow.
				Posted: Wed Oct 12, 2011 8:34 pm
				by marchermitte
				I'm already im faste mode.
