OctaneServer Prime Crashing Randomly
Posted: Sun Jan 04, 2026 10:14 pm
by DarkCat736
Hello!
I am using Octane Render Prime with Blender and I created a scene and then tried to render it, however after rendering a random amount of frames (usually 2-10) the render view has an error message reading "Error in render server" and the OctaneServer crashes. If I restart the server and have the render pick up from where it left off, it will continue rendering for a couple frames before crashing again. The system resources don't go above 50% and I couldn't find any logs so I'm not sure what is wrong. Does anybody know what might be happening? Thank you!
- Kiran
Re: OctaneServer Prime Crashing Randomly
Posted: Tue Jan 06, 2026 8:46 pm
by Inferno3221
Have the same issue. Rendered one whole 250 frame animation today. After trying to render another one, the server keeps crashing after 4-16 frames. Restarting neither the server nor pc solves the issue. Didn't do anything specific to the file between rendering the animations. Definitely seems like a bug
Posted: Thu Jan 15, 2026 8:19 am
by pajamaszap
DarkCat736 wrote: Sun Jan 04, 2026 10:14 pm
Hello!
- Kiran
Hi Kiran, you’re not alone — this looks like a known instability with Octane Render Prime in Blender. Many users report random server crashes between frames, likely a Prime or driver-related bug rather than a scene or hardware issue. Restarting usually doesn’t fix it, so updating Octane, GPU drivers, or switching render modes may help.
Posted: Thu Mar 12, 2026 5:27 am
by 3dhermit
Having same issue, random server crashing when screen goes to sleep. Latest driver 595.79 & blender 5.0.1
Posted: Fri Mar 20, 2026 1:22 pm
by Falkenbach
Try updating your GPU drivers and Octane to the latest versions. Also, check if switching render modes or disabling sleep mode on your system helps stabilize the server.
Posted: Wed Apr 08, 2026 8:25 am
by funnysolo
Looks like it might be GPU/VRAM related. Try updating drivers, reducing scene complexity, or enabling out-of-core memory in Octane—those usually help with random crashes.
Posted: Sat Apr 25, 2026 11:31 pm
by Chamerli
Hello!
- Kiran
It seems that you have a classic instability of the Blender + OctaneServer connection, and according to the description it is more like not an overload of resources, but a failure of the render server or driver layer. Also an important point: if this is the Prime version, it sometimes has tighter stability limits compared to Studio/Enterprise. This is almost certainly either a memory leak or a GPU driver conflict, and not a normal scene error.
By the way, in such GPU rendering systems an analogy is often drawn with risky computational tasks: as in online gaming systems or casino services with bets, there is also a moment of instability and unpredictable results with a large number of repetitions - the system may crash not from the load, but from accumulated small errors in the process.
Posted: Tue Sep 22, 2026 9:13 am
by chipzing
Chamerli wrote: Sat Apr 25, 2026 11:31 pm
Hello!
- Kiran
I’d probably check the GPU driver and OctaneServer logs first, then test the scene with a different driver version. Since it crashes after a few frames rather than immediately, monitoring VRAM usage and running a simple scene could help isolate it.
