OctaneRender 2025.5 for Houdini production (2025.5.0.0)
Posted: Wed Dec 17, 2025 2:59 am
by bruce.chai
This is a production release of the OctaneRenderâ„¢ 2025.5.0.0 for Houdiniâ„¢ plugin compiled with the Octane 2025.5 core. This 2025.5.0.0 release is available for the latest Houdini production builds on Windows x64, Linux, and macOS arm64.
Houdini production builds supported by this release: 20.0.896, 20.5.684, 21.0.440, 21.0.512 and 21.0.559.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
New features
To learn more about the new features and improvements of OctaneRender 2025.5.0, please check out the 2025.5 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2025.5.0.0 Studio+ license
Windows Houdini 20.0.896
Windows Houdini 20.5.684
Windows Houdini 21.0.440
Windows Houdini 21.0.512
Windows Houdini 21.0.559
Linux Houdini 20.0.896 (gcc11.2)
Linux Houdini 20.5.684 (gcc11.2)
Linux Houdini 21.0.440 (gcc11.2)
Linux Houdini 21.0.512 (gcc11.2)
Linux Houdini 21.0.559 (gcc11.2)
Release 2025.5.0.0 macOS Prime license
MacOS Houdini 20.0.896
MacOS Houdini 20.5.684
MacOS Houdini 21.0.440
MacOS Houdini 21.0.512
MacOS Houdini 21.0.559
Release 2025.5.0.0 Demo version
Release Notes
RELEASE 2025.5.0.0
PLUGIN FEATURES AND FIXES:
  • Fixed un-linked octane info pass settings in RT hda
  • Fixed instanced geo in disabled subnet reappear
  • Fixed universal light not updating when changing mode (for example from directional light to analytic light)
  • Fixed IPR alpha showing black when not at 100% zoom
  • Fixed bug where camera selection dropdown would stop working when the IPR button in octane shelf was pressed while IPR was running
  • Update object referring when its referred parameter changes
  • Added warning message when incorrect Octane installation is detected
  • When no opacity node is set in the decal node it defaults to 1 (visible) instead of previous 0 (invisible)
OctaneRender for Houdini tutorial
Still updating
Note
From 2025.1.Beta_1.0, Octane plugin for Houdini uses Houdini package file. Each build ships a script (createPackageFileForOctane.bat for Windows, createPackageFileForOctane.sh for Linux and Mac) to help create the Octane.json file as below under C:\Users\<username>\Documents\houdiniXX.Y\packages on windows, ~/Library/Preferences/houdini/XX.Y/packages on Mac, or ~/houdiniXX.Y/packages on Linux.
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "<path_to_plugin_directory>"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "HOUDINI_MENU_PATH": {
                "value": "$OCTVERSION/config/Menus"
            "HOUDINI_SCRIPT_PATH": {
                "value": "$OCTVERSION/scripts"
            "PATH": {
                "value": "$OCTVERSION/bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION/dso/usd_plugins"
Important Note
2024.1.0.2 fixed the problem that the layered material nodes cannot be loaded properly, however this fix affects all layered material nodes and OSL material nodes in existing saved .hip files. When loading a .hip file for the first time using this build, it's necessary to adjust the connections of these nodes. Once the file is saved with the updated connections, the issue will be resolved.
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package. On some Linux distributions, you may also need to manually create a libglut.so.3 symlink pointing to the current version in /lib/x86_64-linux-gnu.
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
Re: OctaneRender 2025.5 for Houdini production (2025.5.0.0)
Posted: Fri Dec 19, 2025 9:19 pm
by lavrenovlad
Why does Houdini's UI/Viewport feel laggy now when the IPR is running? It literally was fine in 2025.4.0.0, and now I am getting 15 fps in the viewport with nothing but a CUBE in the scene.
