OctaneRender 2026 for AutoCAD [TEST and STABLE]
Posted: Fri Nov 28, 2025 1:05 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for AutoCAD TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date. If in doubt, run Octane Standalone, then add and click on a Rendertarget to make sure it starts rendering.
2) If the Octane Camera direction does not match up with the AutoCAD camera, Rightclick the XYZ axis in the AutoCAD viewport and select "World".
3) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin
AutoCAD Version
The plugin requires AutoCAD 2026 or 2027, Windows 64bit.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
- Operating System (ie. Win 7, 10 or 11)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- AutoCAD version and build number
- OctaneRender for AutoCAD version (ie. 2022.1)
For more information...
- Specific Octane 2.0 features in this plugin http://render.otoy.com/manuals/AutoCAD/?page_id=661
- Read the on-line manual
- Read the (Link FAQ)
- Post your question on this forum thread
- To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
Download Links
Current STABLE build (Octane 2026.6)
Previous STABLE build (Octane 2026.5)
Release Notes
2026.6 - v43 (20-Oct-2026)
- Compiled with Octane 2026.6
2026.5 - v42 (29-Sep-2026)
- Compiled with Octane 2026.5
2026.4.0.41 (1-Aug-2026)
- Added support for AutoCAD 2027
2026.4.0.40 (7-Jul-2026)
- Compiled with Octane 2026.4
2026.3.0.39 (14-May-2026)
- Compiled with Octane 2026.3
2026.2.0.38 (12-Mar-2026)
- Compiled with Octane 2026.2
- Added Metalness AOV node as per Octane 2026.2
- Added the Neural Radiance Cache pin to the Photon Tracing Kernel
2026.1.0.37 (28-Nov-2025)
- Compiled with Octane 2026.1 - see viewtopic.php?t=85315 for details for this release
- 2026.1 features IN this release : AOV's (partially), Displacement, OpenPBR surface material node.
- 2026.1 features NOT IN this release : Vectron changes, Gaussian Splats, MaterialX, LOD Data, CMYK Halftone texture, Trace sets.
- IMPORTANT: IOR and Anisotropy for all materials are now a texture inputs rather than a float, so scenes from previous versions of Octane will loose their IOR and Anisotropy settings. This applies to the Glossy, Specular, Hair, Metallic, Universal and Specular Materials, and the Metallic and Specular Layers
Re: OctaneRender 2026 for AutoCAD [TEST and STABLE]
Posted: Thu Mar 12, 2026 5:15 am
by face_off
I have updated the installers at the top of this thread with:
2026.2.0.38
Posted: Thu May 14, 2026 8:27 am
by face_off
2026.3.0.39
Posted: Tue Jul 07, 2026 6:48 am
by face_off
Posted: Fri Jul 31, 2026 11:28 pm
by face_off
2026.4.0.41
Posted: Tue Sep 29, 2026 7:45 am
by face_off
2026.5 - v42
Posted: Tue Oct 20, 2026 4:23 am
by face_off
2026.6 - v43
