OctaneRender 2026 for Revit [TEST and STABLE]
Posted: Fri Nov 28, 2025 12:41 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit - TEST and STABLE releases.
Revit Version
This version runs on Revit 2025, 2026 and 2027 on Windows Windows 7, 8, 10 and 11, 64 bit.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
- If relevant - supply the Journal file for the Revit session where the support issue occurred. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Revit/?page_id=536
- Read the on-line manual
- Read the (Link FAQ)
- Post your question on this forum thread
Download Links
Current STABLE build (Octane 2026.5)
Previous STABLE build (Octane 2026.4)
Release History
2026.5 - v81 (29-Sep-2026)
- Compiled with Octane 2026.5
2026.4.0.80 (19-Aug-2026)
- Added support for Revit 2027. The Revit 2027 version of the plugin installs into C:\Program Files\Autodesk\Revit\Addins\2027
- Changed the textures file location from "C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\" to "C:\Program Files\Common Files\Autodesk Shared\Materials\Textures\", as the new file location is the default for Revit since Revit 2024. You will need to delete your C:\Users\[username]\AppData\Local\OctaneRender for Revit\config.xml and/or C:\Users\[username]\AppData\Roaming\OctaneRender for Revit\config.xml files in order for this to take effect.
2026.4.0.79 (2-July-2026)
- Compiled with Octane 2026.4
2026.3.0.78 (20-May-2026)
- Compiled with Octane 2026.3
2026.2.0.77 (27-Feb-2026)
- Compiled with Octane 2026.2
- Added Metalness AOV node as per Octane 2026.2
- Added the Neural Radiance Cache pin to the Photon Tracing Kernel
2026.1.0.76 (28-Nov-2025)
- Compiled with Octane 2026.1 - see viewtopic.php?t=85315 for details for this release
- 2026.1 features IN this release : AOV's (partially), Displacement, OpenPBR surface material node.
- 2026.1 features NOT IN this release : Vectron changes, Gaussian Splats, MaterialX, LOD Data, CMYK Halftone texture, Trace sets.
- IMPORTANT: IOR and Anisotropy for all materials are now a texture inputs rather than a float, so scenes from previous versions of Octane will loose their IOR and Anisotropy settings. This applies to the Glossy, Specular, Hair, Metallic, Universal and Specular Materials, and the Metallic and Specular Layers
Re: OctaneRender 2026 for Revit [TEST and STABLE]
Posted: Fri Feb 27, 2026 2:57 am
by face_off
I have updated the installers at the top of this thread with:
2026.2.0.77
Posted: Thu Jul 02, 2026 9:02 am
by face_off
2026.4.0.79
Posted: Wed Aug 19, 2026 3:16 am
by face_off
2026.4.0.80
Posted: Tue Sep 29, 2026 9:24 am
by face_off
2026.5 - v81
