OctaneRender 2026 for Poser [TEST and STABLE]
Posted: Fri Nov 28, 2025 12:23 am
by face_off
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you have the latest Poser Service Release installed.
3) Pls read http://poserphysics.blogspot.com.au/2016/03/before-you-submit-octane-support.html prior to posting support issues.
4) Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin.
5) LiveDb materials containing OSL nodes will not load into the plugin correctly. The plugin does not currently support OSL Projection or Texture nodes. Instead, copy these Livedb materials into the clipboard from Octane Standalone and paste them into a NodeGraph material in the plugin.
5) If you get render artifacts at a joint between two Body Parts of a Figure, switch the Figure's Skinning Method to "Poser Unimesh".
Poser Version
This release only runs on Poser 12 and Poser 13. It will not run on Poser 11
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 452 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- OctaneRender for Plugin version (ie. 2.23.1.56)
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- Operating System (ie. Win XP, Vista, 7, 8)
- Amount of RAM
- Nvidia driver version
Also have ready a copy of
- octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory), and
- config.xml, which is in C:\Users\[username]\AppData\Roaming\Poser Pro\9 for Poser 9/2012 and C:\Users\[username]\AppData\Roaming\Poser Pro\10 for Poser10/2014.
If you have questions
- Read the latest up-to-date on-line manual
- Read Wim's Poser Plugin User Guide
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Watch the Instancing Video
- Watch the HDR Light Studio Video
- Post your question on this forum thread
Download Links
Current STABLE build for Poser 12 and Poser 13 (Octane 2026.6)
Previous STABLE build for Poser 12 and Poser 13 (Octane 2026.5)
Release Notes
2026.6 - v133 (15-Oct-2026)
- Compiled with Octane 2026.6
2026.5 - v132 (22-Sep-2026)
- Compiled with Octane 2026.5
2026.4.0.131 (17-Jul-2026)
- Compiled with Octane 2026.4
2026.3.0.130 (1-May-2026)
- Compiled with Octane 2026.3
2026.2.0.129 (12-Mar-2026)
- Compiled with Octane 2026.2
- Added Metalness AOV node as per Octane 2026.2
- Added the Neural Radiance Cache pin to the Photon Tracing Kernel
2026.1.0.128 (28-Nov-2025)
- Compiled with Octane 2026.1 - see viewtopic.php?t=85315 for details of this release
- 2026.1 features IN this release : AOV's (partially), Displacement, OpenPBR surface material node.
- 2026.1 features NOT IN this release : Vectron changes, Gaussian Splats, MaterialX, LOD Data, CMYK Halftone texture, Trace sets.
- IMPORTANT: IOR and Anisotropy for all materials are now a texture inputs rather than a float, so scenes from previous versions of Octane will loose their IOR and Anisotropy settings. This applies to the Glossy, Specular, Hair, Metallic, Universal and Specular Materials, and the Metallic and Specular Layers
Re: OctaneRender 2026 for Poser [TEST and STABLE]
Posted: Sat Jan 03, 2026 7:05 am
by Petec
Hi Paul, thanks for the update I appreciate it. I haven't installed just yet as I am mid-project on a few things and I'll have to rebuild many of my material presets with the specular/metallic changes. Question(s) for you though:
(1) I don't see it explicitly mentioned in your notes but is the neural radiance cache system (i.e. faster lighting cleanup on the first few pixels) working in the Poser plugin?
(2) Is it correct that with the new version (2026) I can only render if I have an active internet connection (i.e. if my internet cuts out, rendering cuts out)?
Posted: Sun Jan 04, 2026 7:18 am
by face_off
I don't know for sure - but my best guess is "Yes'.
I believe this is the case - yes.
Posted: Thu Mar 12, 2026 4:08 am
by face_off
I have updated the installers at the top of this thread with:
2026.2.0.129
Posted: Fri May 01, 2026 4:32 am
by face_off
2026.3.0.130
Posted: Fri Jul 17, 2026 12:25 am
by face_off
2026.4.0.131
Posted: Tue Sep 22, 2026 9:24 am
by face_off
2026.5 - v132
Posted: Thu Oct 15, 2026 5:00 am
by face_off
2026.6 - v133
