Smooth test for soft shadows: [email protected] size vs micro-dot sphere light
Posted: Fri Nov 14, 2025 9:46 pm
by nuno1980
Hello.
[email protected] size: soft shadows are unsmooth - BUG
Artificial micro-dot sphere light: soft shadows are perfectly smooth - CORRECT
- Download - free ORBX project -
-> open this project and choose to click one of 2 "Render target" nodes to start rendering: "
[email protected] size" and "Artificial micro-dot light"
Best regards.
Re: Smooth test for soft shadows: [email protected] size vs micro-dot sphere light
Posted: Wed Nov 19, 2025 5:54 pm
by nuno1980
@roeland or @mojave:
Hello. Can you find the issue at the daylight env.?
Best regards.
Posted: Wed Jan 21, 2026 12:22 pm
by nuno1980
Hello, guys.
New 3 screenshots but at [email protected] size only (not any artificial light):
Box@specular with ior ~1.33 for test - if shadows are smooth or unsmooth
Unsmooth as bug shadows by caustics at Progressive Photon Mapping (PPM) method under Photon Tracing kernel
Smooth shadows by caustics at PT kernel
---SOLUTION--- / for avoid any bugged shadow from ultrathin sunlight (eg: lower than ~0.3x size) source on Daylight environment only:
- should change the kernel to Path Tracing,
must disable "caustic blur" as "0" (0.01 by default and SORRY for long time render as few or many hours to be enough caustics
) and must enable "Nested Dielectrics";
- add a box, add "specular" material node for this with air@ior 1.00029 or w/ vaccum@ior 1.0 and should change the priority to ALWAYS lower number than any other object;
- any object must be always inside of air with or w/o fog or of vaccum.
-> Enjoy and Happy Rendering!
Or we wait for fixed bug/unsmooth shadows at ultrathin sunlight source in next version of OctaneRender.
Best regards.
Posted: Fri Aug 14, 2026 3:23 am
by karl
Thanks for the report. This issue will be fixed in the next 2027.1 build.
