Files!
Posted: Thu Oct 09, 2025 11:05 am
by affixxius
Hello.
Lets say Im making a material, i import a psd that contains an alpha, i must place it in an image tex node and then duplicate and change type to be able to use the alpha.
Is there a way to not have to use two image tex nodes? I often have to reuse a material and change out the tex, I know it doesnt seem like much extra work doing tow nodes but it is when I need to do like 50 or more.
Im guessing that the image tex node reads only rgb OR alpha so my hopes of using another node will be dashed?
Or is there some way to make the image tex nodes path (that will be the alpha one) copy the rgb one? like be an instance of it but with a different type selected?
Im pretty sure There isnt a way but i live in hope!
It would certainly be nice if the Image tex node just had an alpha out pin.
Thank you,
be well
AK
Re: Files!
Posted: Mon Oct 27, 2025 10:21 am
by ChrisHekman
In the 2026 build of Octane image nodes will output all 4 channels of the texture. We havnt implemented this yet for existing RGB image nodes in the plugin yet.
When we do I am thinking of adding multiple output pins similar to how it is done in Unreal. I have added a ticket for this.
Unreal example:
Re: Files!
Posted: Mon Oct 27, 2025 10:38 am
by affixxius
Thanks Chris, that's great stuff! That will be real handy
Cheers
AK
