Cinema4D version 2025.2.1 - v1.6.1 Hotfix
UON.Visuals wrote: Sun Aug 17, 2025 1:21 am Not sure if this has been fixed yet, I am still on 2025.1 becuse of the issue with half my render nodes crashing
I have a super simple scene but it uses an animated texture made of 4500 EXR images. For some reason, rendering the scene fills up my ram over time until C4D crashes or freezes. Shouldn't it just be reading each EXR image one at a time as each frame is rendered?
The ram stays full even if I stop the render and then open up a blank scene in Live Viewer
If this is already fixed in 2025.2.1 that's awesome, but I still can't use it. Will the render node issue be fixed on next release?
Render Node issue in 2025.2 has been fixed in 2025.2.1, please update both c4doctane plugin and Render-Nodes to latest 2025.2.1 version and report back, thanks.
Here is the link to Render-Node 2025.2.1 version:
https://render.otoy.com/customerdownloads/000_obd/208/5cdd7bc1/60/80/26/fb/OctaneRender_Studio+_2025_2_1_node_win.exe
ciao,
Beppe
KeeWe
Hi Bepe,
would it be possible to always post a link to the corresponding render client when posting new vresions? It would be a much appreciated QoL addition. :)
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
protokol
Ok thanks for looking into that Bepe, glad to know its only affecting live viewer.
tim_grove
bepeg4d wrote: Thu Aug 07, 2025 7:49 am
tim_grove wrote: Thu Aug 07, 2025 1:59 am
tim_grove wrote: Mon Jul 28, 2025 3:21 am Hi, have the bugs related to chaos nodes from V1.5 been solved yet?
Anyone? I've checked about 7 changelogs between the standalone and C4D releases and can't find any information on what's happening or when it will be fixed.
Hi Tim,
About Chaos texture, sorry, do you mind to share a scene with me via PM?
ciao,
Beppe
Hi Beppe, yes I've already done this with Chris Hekman some months ago. Please confirm with him.
desire
Dissmissing behavior of transform data with mix node and StandartSurface material
Haven't check on other mat types yet. Upd.: Diffuse mat has the same or just a bit different behavior.
Please see screenshot
desire wrote: Thu Aug 21, 2025 12:05 pm Dissmissing behavior of transform data with mix node and StandartSurface material
This should be fixed in new 2025.3 SDK, so it should be already fixed for next plugin update.
ciao,
Beppe
desire
bepeg4d wrote: Fri Aug 22, 2025 8:09 am This should be fixed in new 2025.3 SDK, so it should be already fixed for next plugin update.
Nice to hear!
UON.Visuals
bepeg4d wrote: Mon Aug 18, 2025 8:02 am
ciao,
Beppe
The immediate crashes stopped, but those nodes still crash after a few mins of rendering (sometimes they lasted up to an hour). Everything was updated to the same version. The only version that the nodes stay on for the entire length of the render is 2025.1
UON.Visuals wrote: Mon Aug 25, 2025 8:44 pm
Weird, you are the first one reporting this!
Please write to help at otoy dot com asking for Beppe, we need some logs and possibly a scene that shows the issue.
ciao,
Beppe
akvahouse
Hello, can you help me please, I have a problem with light linking, when rendering in picture viewer I`ve lost all my light links. But in Live viewer all works almost perfect. I chose c4d light linking style.
Win 11 x64 | Amd threadripper 1950x | 128gb | Rtx 3090ti
