Custom Realistic Lense
Posted: Fri Apr 11, 2025 3:38 pm
by interelectronix
Is it possible to build custom Realistic Lens presets ?
Re: Custom Realistic Lense
Posted: Sun Apr 13, 2025 3:43 pm
by interelectronix
Does that mean the Realistic Lense is "only" the Universal camera with predefines presets ?
Posted: Sun Apr 13, 2025 6:44 pm
by interelectronix
I dug a bit in the code and it really looks like the lenses are hardcoded into the binary and no parameters are accessible anywhere.
I was hoping that the final implementation would end up like the lens sim plugin https://superhivemarket.com/products/lens-sim
where you can replicate the lense stackup and you are good. Lense stackups are quite available https://www.photonstophotos.net/General ... lBench.htm
I would also appreciate Otoy build a bit more on the amazing user base. There are so many talented people - like you - that are contributing so much and user generated lenses would be amazing. I don“t get it why they are not tapping into this potential.
I tried to rebuild a few Canon Prime Lenses and the results are nothing to get excited about.
I tried to collect many parameter by ChatGpt but still very early work in progress and nothing is really checked just a very quick test with the 35mm parameters.
The optical vignetting is quite puzzling because it behaves somewhat strange.
Any comments appreciated
PS: Yes I saw the chromatic aberation slider and I love it.
Markdown
| Parameter | EF 24mm f/1.4L II | EF 35mm f/1.4L II | EF 50mm f/1.2L | EF 85mm f/1.2L II | EF 135mm f/2L |
| Camera Mode | Thin lens | Thin lens | Thin lens | Thin lens | Thin lens |
| Spherical Distortion | 0.00 | 0.00 | 0.05 | 0.08 | 0.00 |
| Barrel Distortion | 0.10 | 0.05 | 0.00 | 0.00 | 0.00 |
| Barrel Distortion Corners | 0.05 | 0.03 | 0.00 | 0.00 | 0.00 |
| Spherical Aberration | 0.08 | 0.05 | 0.10 | 0.12 | 0.04 |
| Coma | 0.04 | 0.02 | 0.05 | 0.07 | 0.01 |
| Astigmatism | 0.02 | 0.01 | 0.02 | 0.04 | 0.01 |
| Field Curvature | 0.10 | 0.08 | 0.05 | 0.06 | 0.02 |
| Autofocus | Yes | Yes | Yes | Yes | Yes |
| Focal Depth | 0.80 | 1.20 | 1.50 | 2.00 | 2.80 |
| Aperture | 0.71 | 0.71 | 0.58 | 0.58 | 0.71 |
| Aperture Aspect Ratio | 1.0 | 1.0 | 1.0 | 1.0 | 1.0 |
| Aperture Shape | Polygonal | Polygonal | Polygonal | Polygonal | Polygonal |
| Aperture Blade Count | 8 | 9 | 8 | 8 | 8 |
| Aperture Edge | 0.90 | 0.85 | 1.00 | 1.00 | 0.95 |
| Aperture Rotation | 0.00 | 0.00 | 0.00 | 0.00 | 0.00 |
| Aperture Roundedness | 0.85 | 0.90 | 0.80 | 0.75 | 0.85 |
| Central Obstruction | 0.00 | 0.00 | 0.00 | 0.00 | 0.00 |
| Notch Position | -1.00 | -1.00 | -1.00 | -1.00 | -1.00 |
| Notch Scale | 0.50 | 0.50 | 0.50 | 0.50 | 0.50 |
| Custom Aperture | None | None | None | None | None |
| Optical Vignette Distance | 0.015 | 0.020 | 0.020 | 0.025 | 0.010 |
| Optical Vignette Scale | 1.10 | 1.03 | 1.20 | 1.30 | 1.10 |
| Split-focus Diopter | Yes | Yes | Yes | Yes | Yes |
| Diopter Focal Depth | 1.05 | 1.10 | 1.12 | 1.15 | 1.20 |
| Diopter Rotation | 0.00 | 0.00 | 0.00 | 0.00 | 0.00 |
| Diopter Translation X | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 |
| Diopter Translation Y | 0.000 | 0.000 | 0.000 | 0.000 | 0.000 |
| Diopter Boundary Width | 0.60 | 0.55 | 0.60 | 0.70 | 0.65 |
| Diopter Boundary Falloff | 1.00 | 1.00 | 1.00 | 1.00 | 1.00 |
| Show Diopter Guide | No | No | No | No | No |
