MacBook Pro and Octane Render,
Posted: Tue Apr 01, 2025 7:33 pm
by Anhelina
Hello! Need help.
I work with a MacBook Pro (chip M2Pro )
MACOS 15.3.1 (24D70)
Cinema 2025
bought Octane Render, according to the data on the site
I get error! Does Octane work on a MacBook at all if there is no video card?
Re: MacBook Pro and Octane Render,
Posted: Sat May 24, 2025 3:18 pm
by sr.alex
Hi, I think you should use the Octane X (MacOS Metal), be sure the version you download doesn't include the word CUDA.
Posted: Wed Jun 11, 2025 8:24 am
by bepeg4d
please install the latest stable version:
https://render.otoy.com/plugindownloads/a3/c3/8c/da/OctaneRender_Prime_2025.2_for_Cinema4D_v1.5.1_OSX.zip
Note that you always need to remove from the OctaneRender folder, all the unnecessary c4doctane-R2X.xdlib files not related with R2X specific version, and leave only one c4doctane-R2X.xdlib file in ../plugins/OctaneRender directory.
ciao,
Beppe
Posted: Sun Jul 13, 2025 9:54 am
by francisjose2016
But this is not OctaneX ? Octane is not showing up with the version you shared @bepeg4d
Trying to use MacBook pro m4.
on Sequioa 15.4
Still no luck.
Posted: Mon Aug 18, 2025 6:31 am
by bepeg4d
OctaneX was the old name of OctaneRender for old intel/AMD macs.
You own a new Apple Silicon M4 mac, so no needs for old outdated OctaneX version, you can install the latest stable version as for CUDA PC.
Here is the direct link to latest version 2025.2.1-v1.6.1:
https://render.otoy.com/plugindownloads/07/0e/79/38/OctaneRender_Prime_2025.2.1_for_Cinema4D_v1.6.1.zip
Please also make sure to have disabled the "Open using Rosetta" option in the Info panel of the Cinema 4D.app, or plugin cannot be loaded:
And to have updated Maxon C4D to a recent build, for a correct installation of OctaneRender plugin for macOS Sequoia, firstly you need to update your Maxon C4D to a recent build, (R25.117, R26.107, 2023.2, 2024.4, 2025.0.1), or plugin cannot be correctly loaded.
ciao,
Beppe
Posted: Fri Sep 26, 2025 10:59 am
by JackMichael
Anhelina wrote: Tue Apr 01, 2025 7:33 pm
Hello! Need help.
Cinema 2025
I have the same problem. I still haven’t found a solution.
Posted: Mon Aug 10, 2026 10:35 am
by tautcovert
Hello! Need help.
Cinema 2025
Octane supports Apple Silicon, but check your Cinema 4D and plugin versions.
