Vectron Displacement samples
Posted: Mon Feb 10, 2025 11:43 pm
by neonZorglub
[Available from version 2025.1 Beta1 - 16.01]
The new Vectron displacement node lets you displace a Vectron or a Volume SDF with an input texture.
It works in real time, at any scale, and is compatible with complex SDF trees or Mesh Volume SDF. You can also use a field texture to limit the area of action.
You can achieve virtually endless detail by stacking noises on top of each other giving you great results at minimal cost.
[ref: viewtopic.php?f=33&t=84310]
Here are some samples:
Vectron_Displacement_Samples.zip
(110.22 KiB) Downloaded 233 times
3 different vectron shapes are used as input of 3 vectron displacement objects.
each one uses a different displacement texture.
A Vectron Substract operator is used as the input of a vectron displacement object.
Note the new option 'No Render' added to all Vectron objects, that can be used to hide intermediate objects when rendering.
