OctaneRender® for 3ds max® v2024.1.2 - 15.12
- imanshirani
- Contact:
2024.1.2 - 15.12 has issue with network rendering
in stand-alone
- paride4331
imanshirani,
Have you installed the plugin and daemon with the same SDK version?
Regards
Paride
Regards
Paride
- imanshirani
- Contact:
yesparide4331 wrote:imanshirani,
Regards
Paride
OctaneRender_Studio+_2024_1_2_node_win
OctaneRender_Studio+_2024_1_2_win
OctaneRender_Studio+_for_3ds_Max_2024.1.2_-_15.12
- paride4331
Hi imanshirani,
Could you try manually setting the same master network port in the plugin as the standalone version?
Regards
Paride
Regards
Paride
- MartinBoom
since versions 15.11 and 15.12 i'm having several and constant crashes when rendering into octane viewport (open octane viewport)
running the Nvidia studio drivers 572.16 (latest when posted) and previous versions (of drivers and octane 15.11) also had the same issue.
3ds max 2018.
the scenes are not that big (below 2 millon polys) forestpack but minimal.
i not able to isolate what could causing it but, as the copying any texture black body with ies was crashing. i think it has to do to the stability of the build itself.
unusual and a workflow killer.
regards
martin
3ds max 2018.
regards
martin
- paride4331
It seems I can reduce my issues, raising the GPU Headroom to 1024MB.
I also can eliminate the bug with forest objects not being visible anymore on later frames in some cases, when I not use them as a moveable proxy. But not nice in animations.
PURE3D Visualisierungen
- imanshirani
- Contact:
YES but not workingparide4331 wrote:Hi imanshirani,
Regards
Paride
