OSL camera compile
Posted: Sat Dec 21, 2024 12:16 pm
by michaelskripin
Hey everyone!
I’m experimenting with connecting different OSL scripts to the OSL camera from the Vectron Tools, but the ‘Compile and Build GUI’ button doesn’t seem to work. I also tried copying the code directly into the ‘OSL Code’ input, but no luck there either.
The scripts themselves work fine in the camera, but I can’t control them at all.
Has anyone else run into this? Any tips on getting the GUI to show up?
Appreciate any help!
Re: OSL camera compile
Posted: Sat Dec 21, 2024 2:15 pm
by ricky_otoy
Hi there!
OSL Camera seems to be working ok here, see if this works for you:
shader OslCamera(
float Distortion = 0.0
string help = "Lens distortion",
float min = -1.0,
float max = 1.0
float Scale = 1.0
string help = "View scale",
float min = 0.1,
float max = 2.0
output point pos = 0,
output vector dir = 0,
output float tMax = 1.0/0.0)
pos = P;
vector right = cross(I, N);
// Apply scale and distortion to UV coordinates
float uu = (u - 0.5);
float vv = (v - 0.5);
// Optional radial distortion
if (Distortion != 0.0) {
float r2 = uu * uu + vv * vv;
float f = 1.0 + Distortion * r2;
uu *= f;
vv *= f;
// Apply scale
uu *= Scale;
vv *= Scale;
dir = I + right * uu + N * vv;
Posted: Sat Dec 21, 2024 4:50 pm
by michaelskripin
Just test it. Unfortunately, it doesn't work. I pasted the code and clicked the 'compile and build GUI' button, but nothing happened.
I tried reloading Houdini, but that didn't help.
MacOS Sequoia 15.1.1, Octane 2024.1.2.0, Houdini 20.5.445
Posted: Mon Jan 20, 2025 3:57 pm
by marcikola
also not working for me
Posted: Tue Jan 21, 2025 8:05 am
by ricky_otoy
Ok thanks will look into it further. It had worked my side but will see what the issue may be.
What builds are you using too @marcikola?
Posted: Tue Jan 21, 2025 6:24 pm
by scaprendering
Here it worked, just be sure that octane live viewer is not paused or it won't compile !
Feel free to reach out directly if you have issues with V tools
